hi guys, i have just bought my third surf and as usual im here looking for a bit of help.
its a 1992 2.4td and the windscreen demister is not working, i have has a look at the white levers under the drivers footwell and they seem to work ok so im starting to think it has a blocked pipe, is there anything else i should check ? with winter coming i really need this fixing.
also the speedo has a mind of its own, it sticks alot false reads alot, do i swap the binnacle over or could it be some type of sensor ?
any help will be great guys.
