hey there jus looking 4 a bit of advice if anybody can help, i have a 93 toyota surf 2.4d, just recently the tickover seems 2 have dropped and when its idle its sitting at bout 550, also sumtimes when im driving and im comin 2 a stop the engine cuts out, any advice? cheers
toyota surf 93 2.4
Ah one of the helpfull people I was refering toOriginally posted by MattF View PostI'd start with the basics and check/replace the air/fuel filters first.
Matt here's a bit more info on the problem above
"i bought the above vehicle about 3 mnths ago, everythin was runnin ok until a couple of wks ago, it started 2 cut out out when slowing down i.e comin 2 a t junction, it also cuts out when its in idle, tickover has dropped 2 about 550, and now the colder weather has come it seems 2 take ages 2 start in a morning, so i took it 2 a garage and he did a diagnostic check, he told me the solenoid on the diesel pump has gone, can i jus get the solenoid or should i replace the pump? also there was also a slight oil leak from the head, he said it needs skimming and a new head gasket kit, this is why its takin a while 2 kick in in the mornings he says because the head is loosin pressure, any kind of help would be most appreciated thanx lee"
surf probs
hey thanx 4 the info guys its much appreciated, ill do the basic stuff 1st then will go from there, that other garage did the diagnostic check on the ecu and thats the problem he said it was , the solenoid on the fuel pump, so will get another 1 done jus 4 a 2nd opinion, anyway thanx again guys will let u know how i get on
cheers lee
Hi Lee,
have a look at this.
http://www.toyotasurf.asn.au/techsite/efifaultcodes.htm
Hope this helps. All you need is a paper clip.
Gman.If it aint broke, keep goin' till it is.
