Is the 3.0L coupling the same as the 2.4 one?
Viscous coupling.
Originally posted by wishbone View PostIf the 3.0 fan is bigger that could be useful info to the 2.4 owners..
I found refurbing the Viscous Coupling made a huge difference to my 2.4. Can't remember if you've done that yet?Do you know that, with a 50 character limit, it's
Hi Andy,
Things are ok... not great but
Yep I refilled my fan with toyota oil when I did the head. Made it roar!
Anyhow check you out Mr 3.0!! You better be running some power cables or something in that baby......... Stereo Install? You leave it much longer you'll be deaf
Rob.
Aye I know, did what I said I wouldn't!
Will get on with the install soon, got a few things to do to the truck first, then will start running cables at least.
I knew there was a reason for not doing the install in the 2.4!Do you know that, with a 50 character limit, it's
