Viscous coupling.
  • Viscous coupling.
    Is the 3.0L coupling the same as the 2.4 one?
    The fins are different sizes.I found this out on Pirate storms truck.I suppose you could fit a 2.4 one on a 3.0l without rubbing probs on the cowling like you do if you put a 3.0l one in a 2.4
      When you say fins, do you mean the fan blades?
        yea sorry thats what i meant to put
          Good, so the actual coupling is the same. Something else to keep from my old truck. Along with Matt's striking blue fan.
            i will double check for you tomorrow or tuesday but i'm certain the couplings are the same tho
              Different part numbers, different engine? I don't know for sure, but I somehow doubt they are interchangeable.
                If the 3.0 fan is bigger that could be useful info to the 2.4 owners..
                  Hi Rob, hows things?
                  I found refurbing the Viscous Coupling made a huge difference to my 2.4. Can't remember if you've done that yet?
                    Hi Andy,
                    Things are ok... not great but
                    Yep I refilled my fan with toyota oil when I did the head. Made it roar!
                    Anyhow check you out Mr 3.0!! You better be running some power cables or something in that baby......... Stereo Install? You leave it much longer you'll be deaf
                    Rob.
                      Aye I know, did what I said I wouldn't!
                      Will get on with the install soon, got a few things to do to the truck first, then will start running cables at least.
                      I knew there was a reason for not doing the install in the 2.4!
                        The 2.4 coupling does not fit on the 3.0 engine because the alignment hole for the water pump on the 2.4 is smaller. It can be drilled out to fit if you have the correct tools to do it.
                        I'm a custard donut monster
