Originally posted by Bathafarn
View Post
BTW, code 14 is Timer Control Valve. It could be clogged filter in the pump, incorrect timing or a number of things.
You have had the head gasket changed so there's many things that if done wrong can cause problems. We need more of an idea where to look. I suggest check the timing first.
Nev
