hi guys, i have just brought a 2l-te surf. has just had a rebuild and runs really well except for the first start in the morning. it blows out enormous amounts of grey smoke and seems to run on 3 cylinders for about a minute. i have just replaced the glow plugs and diesel filter and that is when the problems really started.
it wouldnt start unless i primmed it and remove the hoses off the fuel filter so replaced the primer pump thinking that is was leaking air into the lines. but no difference. so have replaced the fuel lines and hose clamped them on. the injector pump doesnt appear to be leaking at all, but 3 of the injectors appear to have small leaks on the outside. Im thinking about getting the injectors overhauled is this the right track to be going down?
oh and forgot to mention when driving and changing up the gears it holds the revs for a couple of seconds before letting them drop, has anyone else has this problem?? im thinking the injector pump hasn't been set up right???
ant help would be greatly appreciated i really want to get it runnung right
, and starts a whole lot better now but still blows white smoke for a couple of minutes till warm.
didn't have his
on !!
