Okay, I've read all the posts on tailgate / rear window problems, but cannot find the answer to my own little headache so can anyone out there help.
Situation is rear window stopped moving half way up this afternoon. Trying on the key I can hear the motor working, both up and down, but no window movement - so first assumption is the gearbox on the motor has shed a few teeth.
I've taken the carpet panel off the inside of the tailgate, and the metal trim cover and it's plastic undersheet, and can see the mechanism and the motor / gear assembly. I've found a replacement motor / gear box at rough trax (£140 - is there anywhere better / cheaper you can recomend ??) and am all set to change them over.
Problem is - how does the motor / gearbox assembly come out ? I've read of other posts describing undoing three bolts to remove the motor - there are three on mine but they are on the inside (ie facing into the tailgate cavity. The only way I can get to these bolts would appear to be to remove the four bolts securing the whole window mechanism, and removing the entire thing - latch and lock connecting rods, all the electrics etc - and before I can do that I'm going to need to detach or remove the glass itself from the mechanism, which seems an awfully complicated process to change the motor....
So gentlemen (and ladies), any helpful suggestions would be mighty welcome......
