This is starting to be a pain to solve.
All linkages are free, the auto adjuster is moving as it should, everything in the hub is clean and as it should be, on the rear of the hub the pivot bracket is releasing fully, I have backed off the balancing bolts on the problem side and it has the full releasing distance to it's self.
Now I back off the auto adjuster refit the hud and it runs freely, pull on and off the hand brake to make the auto adjuster work and I'm left with a binding brake again.
Tried filing off the leading edges of the shoes, removing any step in the hub although there was very little to remove if any, giving the shoes and hubs a good rub over with sand paper but I still have not solved this.
Could the hubs be not round inside?
Any other ideas?
Thanks for your thoughts?
Any other ideas?
