Looking for LSD and axle info
  • Looking for LSD and axle info
    I'm looking for a LSD axle/diff but unsure what to look for as in number and what there fitted too.
    Basicly i'm after an LSD diff with a ratio of about 3.5 to 3.9. Its not to go into a hilux.
    Or can i get any LSD equiped axle and just re-gear it? What diffs are the same/interchangeable?
    And what sort of prices do they go for.
    Rob
    Think i've worked out the code thing.
    G035
    I guess that the G is the what the 8" axle is refered to?
    The diff ratio can be 03 up to 06 and quite a few others too. But are they all available in the G axle?
    What year is the G type fitted from to?
      You're looking for a G in either 03, 04, 05, 06, or 07 depending on ratio and a 5 as the last digit. No idea if they all come in the LSD.
      http://www.off-road.com/trucks4x4/ar....jsp?id=274535
        you need a diff with number 5 on the end that is an lsd i have various ratios that i sell for £100 posted
          Examples ...
          Open Diff G244
          Lsd Diff G245
          Good Luck
          There's always a Payback .... Don't know where n ya wont know when !!!!
          Buncefield Burner
            What size axle would be fitted to an LN130 1992 surf? Its it still the 8" diff, as i can't get the axle code for it.
              Are the 4runner axel codes marked up the same as the surf cause i thought they were a bit different
