I am new to Hilux Surf's, bought a 92, 2.4TD about 5 weeks ago that had been off the road for about 3 years. I have now got it back to working order, almost! However, when I start it up, I get a buzzer, which I understand is an "ignition on" buzzer (from reading threads on your forum, great forum), however, I assume it should switch off after starting and running, which is doesn't! Any ideas?
Ignition On Buzzer Continuous
Is it the door open buzzer or the ignition on beep? Is it on all the time, even when driving?Originally posted by noblewilson View PostI am new to Hilux Surf's, bought a 92, 2.4TD about 5 weeks ago that had been off the road for about 3 years. I have now got it back to working order, almost! However, when I start it up, I get a buzzer, which I understand is an "ignition on" buzzer (from reading threads on your forum, great forum), however, I assume it should switch off after starting and running, which is doesn't! Any ideas?Do you know that, with a 50 character limit, it's
The ignition on thing is more a beep than a buzz, that's why I ask. Either would drive me bonkers if they were on all the time!
There are instructions on here on how to disable them. But I can't be arsed looking for you just now, they are here though.Do you know that, with a 50 character limit, it's
I this what your after mate.
http://www.hiluxsurf.co.uk/forums/sh...ghlight=buzzerIf its not broke don't fix it.
is it the door open or 'turn the key' noise?
If its the ignition sound, NOT the door sound, then it indicates a dodgy altenator output - mine did it until i replaced the alt. then it was fine.
Its often accompanied by the dash lights staying on.
Hope that helps.If you're gonna be a bear... be a Grizzly.
Turn the key noise
That's really useful, as I am also suspicious of the alternator not working fully and your description ties in with the symptons I am experiencing. Will investigate further. Thanks.
NobleKnowledge is knowing a tomato is a fruit, wisdom is knowing not to put it in your fruit salad!
