gearbox help
  • gearbox help
    Once box is split from engine what holds the torque convertor on.
    How do I separate the large metal dome from the engine is it bolted as I can't see any.
    Thanks guys
    Brian
    Six bolts hold it to the flex plate on the engine, turn the engine via the crank pully bolt to get at the bolts. You'll probably have to pry it off when the bolts are removed though.
      Thanks Vince for the quick reply mate.
      Found them now. The engine and box are out as its Wattys truck and its getting a new bottom end, after bending two con rods, after taking a drink of drumclog last week.
      Brian
        blimey
        what happened?
        私のホバークラフト は鰻が一杯です。
          He just told you.
          are your eyes broken?
          Alan
            He just told you.
            just my brain
            drink?
            did he dump it in the river?
            私のホバークラフト は鰻が一杯です。
              big puddle I think, pics are on smc site. I think it's the same lop sided puddle yoshie got his/your truck sideways in last year.
              Alan
                Gearbox
                Hi always leave torque converter connected to gearbox.
                Live Life To The Full
                  Yep cheers mate, all built on box before fitting.
                  Brian
