Hi
I'm going to need to hone the cylinders on my block, and was wondering what grit stones to use.
AFAK, I should use 220 for the main honing / crosshatching, then a 600 grit to get the plateau finish to reduce initial ring wear...
But this depends on the ring material. Are standard hilux rings cast iron, chrom or moly??
P.S. I'm in Pakistan, so I can't just trust the engineering shop to know - their idea of honing is to wrap a piece of emery round an old bore (with no stones)... I take it this is as bad as it sounds??
Can I use 600 emery by hand for the 'brushing' after honing (to get the plateau) in case I can't get 600 grit stones??
Thanks
Daniel
Thanks
Daniel
