Marky, spray it full of WD40, then try a brass drift on the end of the studs, if they still don't move, a club hammer, applied to the hub between the wheel studs never fails. Just hit it inbetween two studs, then move to the next gap, and work your way round, being careful of the wheel studs. You might have to clump it fairly hard, but they should fly out and hit you in the nuts.
worked a treat TONY i wore a bullet proof vest & welding mask those collet things dont half fly out at you
