Panhard rod bracket
  • #31
    Hmmm! Tank on left driver on right may explain why springs are the same.This would even things out.Tank and driver on the right for the 2.4 would explain longer spring.
    Neville
    • #32
      I guess i should swap them and see if it makes a difference - will probably lean towards the opposite side by 1" instead.....at least the front is more or less level!
      I was thinking of aiming for a big drop on the left side - squash the left spring a little
