Ok this is probably a really stupid question (other than to me as i am having brain block at the moment). Should the 4wd button on the side of the selector be pressed in to engage 4wd or released? Mine has been pressed in since i have had the car (1 week), no dash lights in either position, but it does clunk if i release it and then press it back in. I suspect it should be pressed in to engae 4wd? If so then hopefully mine is not engaging correctly as otherwise i assume i could have buggered the 4wd system?
Need to know this as i am worried about driving it until i know the answer.
