Hi Guys - Im new to this so I hope you wont mind helping me out!
I bought my 60K mile 1996 Surf (2nd Gen SSR-X) last October and love it. It seems to be in great fettle - I was the 1st Uk owner after import. However a few issues to sort to make perfect...
1 - Aircon. Works fine (blows icy cold) but occasionally (usually at idle) a sound comes from the engine bay as if the drive belt is slipping. It appears that the belt tension is fine as the noise is coming from the electric clutch that engages when pressing the a/c button. The noise goes away if A/C is turned off. Can this clutch be repaired/replaced cheaply?
2 - Fuel economy : - I can ony get 400km out of a tank before fuel light comes on (worked out at 23-24 mpg). Is this as good as i can expect?
3 - There is delay when engaging 4 wheel drive? It appears to work ok but pulls to th left?
Thanks in advance!
Thanks in advance!
