i have steering wheel wobble on my 3rd gen and i just replaced the worn steering rack bushes thinking it was them but the steering wheel is still wobbling usually when braking, the brake discs look true to me, i found play in the drivers side lower balljoint so im thinking this may be the cause.
if i am to replace it will i need a heavy duty balljoint splitter and can these be hired from anywhere ? will the same splitter remove the tie rod end balljoint too ?
is the worn balljoint likely to cause steering wheel wobble, there is no knocking noise or anything.
