I've got an old 4x4 Hilux and the back drop-down bit is stuck shut. There is a lever that you normally put your fingers in and just pull to open but its doing nothing. Any ideas - please
has the cable pulled out the back of the lever? Or snapped?
When you pull the lever is there any resistance at all? I would imagine when it's all working right there's a bit of resistance as it opens the catches?
OK - I've removed the catch and there is a cable attached to the right hand side but nothing on the other side. How do you manage to get hold of the cable - there doesn't seem to be any room in there!!!
Things are looking better - I've found the other half of the wire and it just hooks into the hole. Trouble is it won't stay there...... the other side has some kind of plastic cover that jams it in. Perhaps I could cut off a bit of a rawplug to fix it What you think....
