Hi there surf fans. I believe the 3rd gen models are lucky enough to have electronic locking differentials factory fitted and I might be lucky enough to get the rear axel and diff housing from a KZN185 3.0TD. I have seen links about fitting the diff housing to your existing axel but can the axel and diff housing from KZN185 3.0TD fit onto a LN130 2.4TD has any one attempted this transplant? Also will it work for the front?
rear axel & diff transplant??
A locker in the axle is a rare option on the 3rd gens. Rocking horse shit springs to mind in fact.
They have a centre locking diff. Which when locked behaves exactly the same as a 2nd gen in 4wd. When unlocked alllows the front and rear props to turn at different speeds so preventing transmission wind up using 4wd on the road.=========
=SOLD UP!=
thanks for the update, i was under the impression that apart from changing the transfer case to an open diff with the option to lock i thought they also did it to the front and rear but i see i have been mislead!
damn toyota they put it in the landcruser!http://www.hiluxsurf.co.uk/showthread.php?t=55797
