TPS/ideas please folks!
  • TPS/ideas please folks!
    Hi all,
    Tied searching but not having much luck on how you actually do this…
    How do you adjust the Idle on the truck? I know it has to do with the timing in conjunction with the TPS but it was running fine up till a couple of weeks ago then when idling it runs at about 500 when I think it should be about 700?
    The idle up works fine but I wondered if it was easy to adjust the TPS, as all I can find is diagnostics for it. Also I am getting some new headlight bulbs and was wondering which ones to get without having to change the loom. (All specs in a different language over here and RoughTrax don’t ship & milners can send but post takes ages)
    Lastly is anyone still doing coil spacers?
    As always thanks in advance folks
    Have a look over on the Oz site. There is an active thread in one of the sections regarding this, I believe.
      Thanks will try, having some probs getting to the site from the work PC tho...
        The easiest way is to adjust the throttle cable.
          This is for the 2L-TE but may be similar.
          http://www.toyotasurf.asn.au/forum/v...ic.php?t=14958
          The 3Ltr adjustment and testing may be in the 1KZ-TE manual which you can download.
            cheers Nev will have a look.
            Eventually got to the Aussie site & got a bit confused about voltages etc etc... seems like a lot of folk seem to think just leave it alone and it has to do more with all the rest of the engine 'terms of reference:- intake butterflies, egr state, air in pump, pump wear, cold engine, fuel dilution, swirl chamber, carbon deposits, internal engine condensation, cold blow by oil in intake
            there are a few possible contributing factors'
            .... it a bit past my understanding truth be told!.
            I have checked the throttle cable also & the pedal has play of about a cm or so but it still seems to open the throttle fully (i.e goes all the way around).
            Going to have a look at Nev's link this avo & will get back if i'm still lost!
              change the air filter/fuel filter
              SWIFT AND BOLD
