Hi all,
Tied searching but not having much luck on how you actually do this…
How do you adjust the Idle on the truck? I know it has to do with the timing in conjunction with the TPS but it was running fine up till a couple of weeks ago then when idling it runs at about 500 when I think it should be about 700?
The idle up works fine but I wondered if it was easy to adjust the TPS, as all I can find is diagnostics for it. Also I am getting some new headlight bulbs and was wondering which ones to get without having to change the loom. (All specs in a different language over here and RoughTrax don’t ship & milners can send but post takes ages)
Lastly is anyone still doing coil spacers?
As always thanks in advance folks
