Hi guys!
Had my Surf for about a month now, and I am well chuffed with it. The only bad point that I can find on it is the air conditioning. My car is a 1992 model and uses the old, now unavailable R12 refrigerant.This works perfectly, but is not as cold as it should be and simply needs re-gassing.
Has anybody converted their system to R134a refrigerant? Do I just need to replace the dryer unit and flush the system, or is it more involved/expensive?
a point a few times that i bought a diy kit using the r413 replacement for r12 ( not r314a ) it goes straight in and ice cold ,,, nothing to change try ebay for the gas .. good luck
if at first you dont succeed..... bollock
