tailgate window down and stuck down
  • tailgate window down and stuck down
    motor whizzing not much else doing, read a post about screwing and glueing
    the motor. The poster placed pictures on the thread but there not there ?
    Help!
    http://forums.bauchan.org/portal/articles.php?rid=0
    =SOLD UP!=
      Sourced a motor and should be going on tommorrow 9th feb
      thanks for all the info and pics!
      can the window be in the down position when fitting the new motor ?
      its hard to tell from the pictures
      Cheers again
        Nope.
          it can, but it's a lot easier with it up, just gives you a bit more room to work.
          I'd do it from inside the boot of the truck, once the old motors out you can push the window up from the bottom, and then put a screwdriver or similar through one of the holes in the mechanism to lock it in place, while you fit the new motor.
          =SOLD UP!=
            Nope.
            oh ok, maybe not then
            to be honest never tried as having the window up does give you that much more room
            =SOLD UP!=
              What are you like.
                Cheers again
                open tailgate then close latches at sides with a screwdriver and the window opens and closes as if the tailgate was shut,,,if you get stuck next time all window motors are the same just the connecting block needs moddifying
                  tailgate done
                  Job done, just a rear shock and brake pads then the man will give me an MOT
                  Thanks for all the info
