Hub Nut
    Originally posted by TonyN
    This is how I removed the cone washers....
    1st time...
    2nd and after times, see Nev's post above.
    Never used a hammer that big but my first attempt at removing cone washers was not good.Destroyed some of them and new ones from Toyota were very expensive.Treat them very gently now.
    Neville
      You don't need to go near the washers, tap with a BFH around the outside of the hub, between the wheel studs, and they pop right out (usually )
