It is another suspension lift question but please bare with me as it does cover some new ground I think…
I have a KZN130 ‘95 model with a 1kzte engine, its tail is dragging on the ground some what so I planed to renovate the suspension, I assumed it is worth doing a lift at the same time.
I Live in Africa and drive off road most days to get places so the off road performance is more important than the looks so I had settled on a moderate lift, I will also struggle to get parts but do have access to a lathe and milling machine.
From reading your very helpful forum I came to the conclusion that:
- A three inch Land cruiser springs and shocks re fit at the back, I can order these parts locally (anyone any advice on parts numbers?)
with a bracket for the Pan rod and Brake balance valve, I will make these up my self, (any one a got a pattern or drawing of these that I can use to Fab up the brackets?)
- a set of Ball joint spacers (Again Home made, drawings/ dims would be great) and new longer front shocks ( Again any part numbers would help)
May be my best option for improved clearance and wheel articulation.
Any help with parts numbers or drawings \ patterns for making up the parts would be great help and much appreciated
Any watch its and warnings would be appreciated too, I have fitted Freewheel hubs already and as I understand a Ball joint spacer should not adversely effect the CV angle, is this the case?
I have read all your posts on the fitting of the parts and look forward to the skinned knuckles and WD40 fumes associated with the rebuild
Many thanks
Matt
Many thanks
Matt
