My condenser for the A/C is under the engine, whereas I`ve noticed that some are in front of the radiator. Was there a reason for this, or was it only tried underneath on certain models? can anyone enlighten me?
Air conditioning condenser
the earlier models have the fan at the front, yours will have twin fans underneathOriginally posted by sleeticusMy condenser for the A/C is under the engine, whereas I`ve noticed that some are in front of the radiator. Was there a reason for this, or was it only tried underneath on certain models? can anyone enlighten me?[font=Times New Roman][size=3]
[size=5][/size]
The air con radiator is under the truck on the auto models because the (water) radiator also has the auto transmission oil cooler built in. Can't put too many things in the same place I guess.Roger
Apart from mine which is at the front despite the Bullet being an auto....Originally posted by GamedawnThe air con radiator is under the truck on the auto models because the (water) radiator also has the auto transmission oil cooler built in. Can't put too many things in the same place I guess.
Linda
www.4x4toys.co.uk
