Hi folks had my surf for 3.5 years now and never had a problem yet.Until now!!!Changed glow plugs,replaced both batteries with new ones,checked all connections and i cannot get it to start "normally" in the morning first thing.I know this sounds strange but if i boil the kettle and tip the hot water over the glow plugs it starts first time then after that its starts first time all day until the following dreaded morning.Listened to the click on glow plug relay and its there straight away but dont seem to here one after 6-8 seconds.Please can anyone shine some light on it.Many thanks in advance
First cold start problems
This may help ...
http://www.hiluxsurf.co.uk/forums/showthread.php?t=900
or check the Buzz bar is fitted correctly ....
There's always a Payback .... Ya won't ever see it Comin tho !!!!Last edited by Diezel Weazel; 31 October 2008, 21:10.Buncefield Burner
Or you didn't put the bus bar insulators on correctly?Originally posted by SoundsDigital View PostCheck the 80amp fuse on the glow plugs. I changed my glow plugs and the fuse kept blowing, I suspect the glow plugs were using more power than the originals.Do you know that, with a 50 character limit, it's
