Please can someone tell me how much fluid to put in? I need to top up because the truck was 'jumping'. I have found the dip stick thing and have topped up with some ATF, this has made it better but don't want to overfill cos I guess this is as bad as having too little. The jumping problem stopped but started again a little bit, so I put a bit more in. Could this mean that I may have a leak or does it take quite a bit fluid to top up.
I have found out that you run the vehicle for a while and then take a reading.
Thanks....... I have just inherited this truck and love it, it's so much fun! But, it's not like running a car!!!!!
Gina
Gina
