Hi to everyone.
This is my first posting on what is a first rate site.
A few months ago I bought 1993 3.0 TD SSR-X (auto) as a second vehicle - a workhorse - it’s been superb and an absolute pleasure to drive.
But now there is a problem…
After a fuel stop on the M42 late one night the engine check light flickered on when I pulled away from the pumps. It went off and stayed off. A good few miles later I lost power when under acceleration. It would go to 60mph then die with the engine light back on. Foot off the gas pedal, coast for bit and the power would return. Soon as I hit 60 the same thing would happen. Then it began to happen at 40. I limped off the motorway and got home using the RAC. (No hard shoulder, no overhead lights on this stretch – too risky breaking down here)! RAC man couldn’t find any problems.
For 2 weeks the vehicle has been OKish with only the odd hiccup. But now it is getting worse. Some things I’ve noticed in the past fortnight, which may or may not be clues:
The symptoms get worse as the fuel tank approaches empty.
Always bad after a re-fuel for a few miles, then gradually improves.
Used to be an instant starter, but now it takes some cranking.
There used to be a sort of whirring/ticking noise near the glove box area, as is something was re-setting itself whenever I turned the engine off. This doesn’t happen anymore.
I have drained the fuel filter and disconnected the batteries but no improvement. Thought it might be worth asking to see if anyone has had a similar problem or can advise on next move.
Chris
Chris
