Hi I have an N reg Japanese import for about 2 years and the garage just failed it on producing too much exhaust smoke. Apparently the emissions just scraped through. The garage I took it to said it doesn't have the expertise to fix it.
When the engine idles it is a bit lumpy, purrs along nicely then shudders for a split second as if it is going to stall. I believe this problem started after the hilux stalled in a sea ford. Water went all over the engine. However it started up again and emerged from the sea fine. (This was about a year ago).
So, I am hoping that you can help with a couple of things.
1) Any ideas what the problem could be
2) Do you know of a good garage in the Southampton area that can fix Japanese imports. I have contacted a few Toyota garages and they also said they only had the mechanical expertise for uk designed Toyotas.
Thanks, Robin.
Thanks, Robin.
