I was wondering if someone could give me advice. I have noticed recently that the temperature gauge swings intermittently between 1/2 way and cold (not always).
The coolant levels seem fine and the radiator is full under checking so, is this just the thermostat opening and shutting and hence water going round the system or is there a fault with the thermostat, the sensor etc..?
Where can I check (would appreciate piccies)..I've very little experience on tinkering on cars
(awaiting manuals from Amazon for guidance). The most i've done is change the brake shoes.
Thanks all..
(awaiting manuals from Amazon for guidance). The most i've done is change the brake shoes.Thanks all..
sorry didnt read that bit
i'll stick to the pop quiz
