Hello mates,
I received last week the SupraStick so soon we'll be swapping the manual for the auto tranny.
I'd need a bit of help so I can make the first configuration on the SupraStick, the fine adjustments will be made later as I test the truck.
I'd need some info...
I think this will be enought so I can configure the SSv4 and take the truck for a spin. If not I can always run it in sequential mode and see where I want the truck to shift.
David
- 3.0TD Torque converter stall speed (I think I read somewhere it was 2200rpm, is right?)
- RPM's of the 1-2, 2-3, 3-O/D shifts in normal D position. I know they are different depending on the TPS but something like a 10% and WOT shifts will be perfect (I can stimate the intermediate shifting points).
- RPM where the torque converter lock-up locks in 3rd and O/D (Does the stock Surf lock the TC in 2nd? Don't think so but...)
- RPM of the downshifts from O/D-3, 3-2 and 2-1 in let's say 0-10% TPS
David
