Flushed with my success at replacing both upper balljoints last week, I sauntered down to the local nuts and bolts specialist and pre-armed myself with the HT nuts and bolts to replace the lower balljoint.
Which, aren't of course needed on the lower one
Anyway, I remove the castlelated nut and vigorously set about the joint with the balljoint splitter and hammer.
Nothing
Ok, consult the manual. Turns out there's a warning. A larage warning written in bold instructing me to support the lower arm with a jack which must remain in place throughout.
Doesn't tell you why though. So, I assume its because the joint will violently fly apart once the balljoint is split. So, I support it and set about the balljoint with the splitter again and.......
Nothing.
Ok, this time I very gingerly release the smaller retaining nuts on top of the joint hoping that the lower arm will drop and enable me to get something else in to split the joint. Like a homemade bomb or the works Fiesta van but........
Nothing.
So, why does the arm need supporting? what will happen if I don't?
Do I need a larger balljonit splitter (mine is the tuning fork type and it tapers to about 20mm or so at a guess,) is it just not wide enough to split it or am I missing something?
Any help much appreciated.
Chris
Nothing
Nothing.
Nothing.
Chris
