Oh dear! Only my second attempt at changing the auto trans fluid and i've only gorn and messed things up.
The first time I did the change, there was something amiss with the sump bung I recall, but, as it nipped up without too much drama, i'd kinda forgotten about it.
Today I went for the second change, and things were looking grim from the start. The sump bung didn't seem to loosen progressivly. It wasn't hard to undo, and it certainly didn't need a hammer to get it started, but it did require steady pressure all the way down.
On re tightening, it seemed to dramatically loosen half way up, and then tightened up slightly. It won't nip up though. You can turn it indefinitely. Ho hum!
Anyway, figuring i'd need fluid in the box, I left it be and filled up anyway..But, it is leaking.
What is the solution? I'm not sure if it's the bung or the sump thats the problem, is one far more likely than the other? And, is there something I can put around or over it for now that won't require a lump hammer and bolster to remove when the problem gets addressed?
Thanks in anticipation of your input..
, and I sense that maybe some have lost patience with me already, thinking maybe, "for crying out loud Mickey, just get on with it!"
I'm just really no good at unbolting things, and really bad at putting unbolted bits back on! I have done a lot of searches, and i'm not relishing the thought of getting the front exhaust off and back on..Warrior stated in a thread that he resorted to sawing his off and then welding it up afterwards!
