From what I can make out, my truck has +2" springs on the back as well as 2" spring spacers and ES300 shocks.
The problem is that the ride is very hard and throws you around all over the place. Off-road is even worse as its just not absorbing the bumps.
I'd like to keep the ride height but I really need to soften things up. Can I just fit standard shocks on the front and mantain the ride height?
For the back I guess I'd need softer +2" coil springs, any recommendations? would I need to change the shock absoeber as well?
Or, would I be better off putting standard springs on the back and accepting a 2" drop or would I then need to drop the front as well?
Chris
Chris
