Has anyone here ever fitter an intercooler on their motor?
intercooler?
ok - now for the answer you wanted (sorry about that!)
http://toyotasurf.asn.au/techsite/performance.htm
lots of writes ups - the first one (with the blue pipes) is mine.Another member of the 'A' team
It makes a noticeable difference. Holds onto top gear longer. Doesn't stuggle up hills like it used to. I regularly see 27/28mpg - not bad for a motor with 267,000kms on the clock.Originally posted by speedymacfish View PostNice.......
Think i've seen your motor......? Was living in North Cornelly until i moved to Swansea......
Does it make a drifference?
Well worth doing. Easier with a body lift though.
mail me if you're back in the area - I'll talk you through it if you want.Another member of the 'A' team
i was just looking at the pics of someone who's taken out the air filter housing and side mounted his..... once i've changed this injector pump i'll be on the look out for a cooler and new air filter. i'm hoping its a straight forward job...lol
i'll be in touch when all goes tits up...lolAlways assume the worst.....Anything less is a bonus!!
coolers
Did your cooler come with a fan, I picked one up over the weekend off a Shogun at a scrap yard and it has an electric fan attached, was thinking that if side mounted and used with a K&N ftype filter, might be able to squeeze the fan in too, what do you think? Would it be worth it?
