anybody know if the clutch can be adjusted and where the gearbox oil filler is situated.ln130 manual.cheers
gear box manual
no to
the adjusted can not be adjusted but you can bleed the slave cylinder if the clutch fluid has lost its viscosity you bleed the slave cylinder and that shouldOriginally posted by richard_challis@yahoo.co. View Postanybody know if the clutch can be adjusted and where the gearbox oil filler is situated.ln130 manual.cheers
short it out if not it sounds like you may have to do a new clutch and if you are
doing a new clutch replace the duel mass fly wheel and do the crank seal behind
the fly wheel at the same time and this will save you time and money not like me as my surf is back off the road after putting a new gear box & clutch and six weeks after doing all that work and the duel has split and i now have to pull the gear box out once more and do the flywheel and this time i will do the rear crank seal n it should be sound this time you will get the parts that you will knead from miliner off road and ask for the clutch kit and solid mass fly wheel
n the 8 flywheel bolts and get the spigot bearing to and you will save time and the caust of pulling the gear box out twice
don't cut the corners like me and have to pull the box out twice
you have bean warnedS S R G is the only way to surf
scottish mud club member kerelawsurf
Try Matt's........ http://forums.bauchan.org/portal/downloads.php' You've arrived on a rather special night. It's one of the master's affairs.'
