I'm having problems with reverse gear & neutral. Also the Hi / Lo transfer lever.
No warning at all and suddenly I can't reverse properly, was fine yesterday not today. When reversing the truck needs loads of revs and goes backwards in judders.
Also the truck is creeping forward while in neutral.
Finally I can only move the Hi / Lo transfer lever of the engine is off, whereas before it would move while in neutral.
Transmission fluid was slightly low but has been topped up.
Truck drives forwards and changes gear with no problem.
I have had a quick look underneath and can't see anything new or missing.
Is it a case of
