Hi all, checked my power steering fluid at the weekend ( fiest time in two years) and it seems low, as there was none on the little dip stick when cold.
I read in the stickies that this is just dexron ATF, so my question is this;
1) What is likely to be in there at the moment
2) can I put any old ATF in, or does it have to be dexron
3) can I mix and match ATF?
4) if I'm unsure would it be best to change it, and if so how?
