Had a niggling rattle for a couple of months thats been driving me crazy
Finally discovered the rear u/j was on it's way out. As the bolts had been tightened by KingKong with a jackhammer I had to take it to the garage to get it removed.
It wasn't till I took it to the specialist I found out that the garage should not have split it without marking where it originally fitted together. They warned it could well vibrate worse than ever if refitted incorrectly.
They were right .....it did.
I undid the rear end & turned it 180 degrees. This was a vast improvement..but there is still a shudder from about 15 -25 mph . Unfortunately this makes it horrible around town.
The garage aren't much help & reckon there should be no difference on such a short shaft.
Somebody else told me there could be 16 combinations...i.e. 4 x 4 ....which is the number of bolts on the u/j at each end.
I can't face fitting and removing it another 14 times...especially as its lashing down outside
Now I know they are balanced..but surely balanced means as long as it is aligned...there shouldn't be a top or bottom etc.
I shouldn't need to try each u/j in each position ,isn't it just the interior spline that needs adjusting ? How many positions does that have ?
Anybody know ??
Anybody know ??
