my diffs on the breaker are R150F G282 are these lsd ones?
diffs
Differential CodesOriginally posted by sledge View Postmy diffs on the breaker are R150F G282 are these lsd ones?
Size of Diff
A=138MM , B=145MM , C=6.25” , D=6.662” , E=7.1” , F=7.5” , G=8’ , H=9” , J=9.25” , K=9.5” , L=10.5” , M=12.5” , N=13.5” , P=14” , Q=12” , R=162MM , S=6.38” , T=6.7” , U=6.0” , V=10.6” , W=15.5” , X=142MM , Y=158MM , Z=202MM
Ratio
01=3.300 , 02=3.360 , 03=3.545 , 04=3.556 , 05=3.700 , 06=3.889 , 07=3.900 , 08=4.111 , 09=4.222 , 10=4.275 , 11=4.444 , 12=4.625 , 13=4.790 , 14=4.875 , 15=5.125 , 16=5.286 , 17=5.600 , 18=5.714 , 19=5.833 , 20=6.167 , 21=6.667 , 22=6.780 , 23=6.833 , 24=7.640 , 25=4.556 , 26=5.571 , 27=3.364 , 28=4.300 , 29=4.100 , 30=3.727 , 31=3.909 , 36=4.778 , 37=3.583 , 39=3.154 , 40=5.375 , 41=3.308 , 42=6.500 , 43=3.550 , 44=3.214 , 45=3.533 , 46=2.929 , 47=3.944 , 48=3.356 , 49=3.729 , 50=3.400 , 51=3.736 , 52=3.722 , 53=3.250 , 54=3.941 , 55=3.333 , 56=2.821 , 57=4.058 , 58=3.238 , 59=3.234 , 60=3.519 , 61=2.724 , 62=2.892 , 63=2.655 , 64=4.312 , 65=3.873 , 66=3.071 , 67=3.526 , 68=3.095 , 69=4.176 , 70=5.857 , 71=2.962 , 72=3.949 , 73=4.285
Different Models of Toyota could be
32=6.591 or 4.807 , 33=7.503 or 5.583 , 34=6.781 or 4.786 , 35=7.636 or 5.600
Pinion & LSD
2 = 2 pinion open diff
3 = 2 pinion LSD
4 = 4 pinion open diff
5 = 4 pinion LSD
Other verification of either 2 or 4 pinion diff is,
On a 2 pinion it will have 3 fins either side of the outer case.
On a 4 pinion it will have 4 fins either side of the outer case.
Or here
http://www.toysport.com/Technical%20...ifications.htmLast edited by Bibs; 9 April 2008, 21:10.How can I be lost when I've got no where to go
So...
A 3.0 front diff is, I believe, a G294; 8", 4.100, 4 pinion open.
A 2.4 front diff is G144; 8", 4.875, 4 pinion open.
Is the 2.4 gearing higher or lower than the 3.0? As I need a front diff I'd like to lower my gearing for the 33" tyres but I can't get my head round it.????Wax on, wax off
Gearing is all different on any given truck, plus the code only tells you the rear diff's pinion and LSD arrangment. (but all front diffs on Surfs are 2 pinion and open anyway, you only need to know the diff ratios and if it has a LSD in the rear)Originally posted by Fordy View PostSo...
We have 4.8's to go in Linda's truck on 33's. 4.1's where rubbish on the motorway and towing, 4.5's are OK, we have then in ATM as a stop gap and might be better if you don't tow as PRM will be slightly lower than 4.8's. But 4.5's and 4.1's with 33's make our truck noticabily slower pulling away, and on long hills on the motorway.4x4toys.co.uk - Keeping you on and off the road...
