Hi guys.... I've looked but can't find any threads on this one so here goes... I've only had my Surf for a couple of weeks and I love it... However the one thing that is really starting to bug me is the odometre reading in kilometres... ( it is true .. when you get older you turn into your Dad...) Any how does anyone know if the u.k. spec ( in miles ) 4 runners instument pod is the same as a 2nd Gen surf... I've got a 94L 3ltr ssrx limited .. It would make my day if it was a straight swap... I've never been in a 4 runner and have no idea if the dash is like.... Cheers. Chris.
4 runner instument pod...
The dial cluster will be the same, but somewhere around 1991-1992 the speedo changed from cable drive to electronic.
If the speedo needle rests on a pin when at zero, then it's electronic. No pin then it's cable driven.
You can buy stick-on MPH speedo faces from roughtrax, but the odometer will still click 'round in KMs.
Hi Guys thanks to all that replied... Just one point to clear up.... are you saying that if I have a 94 L surf it should be electronic instruments... and if i get instruments fron a late (94'ish) 4 Runner they will be a stright swap and the speedo and odometer will read in mph and miles with out using a converter chip or any re wiring .. Sorry to seem thick.... Thanks again... Chris
