hi guys i have a 1992 2.4 ssrx surf LN130 and my speedo has stopped working ive been upside down under the dash but can,t seem to find a cable anywhere can any one help ! Also the O/D OFF keeps flashing is that related ?
speedo not working
Originally posted by scott1chip View Posthi guys i have a 1992 2.4 ssrx surf LN130 and my speedo has stopped working ive been upside down under the dash but can,t seem to find a cable anywhere can any one help ! Also the O/D OFF keeps flashing is that related ?
yes od light flashing is related to speedo not working,more than likely sensor as nev said or may be wiringOnly Toyota can get you out of shite
Mine had the same problem, the speedo did not work and the overdrive light was flashing , i removed the clocks, found a black box that had been wired to the harness[changes kph to mph ] removed this and re connected the wires by colour code , black taped them up [you might want to solder them] and bought a new clock face off ebay , mileage still reads in kph, as does the trip, but with the new clock face, the speed you are travelling reads in mph, and the [overdrive off light], works as it should . £8.56 for a new face or £80.00 for a speed convertor, its up to you hope this helps ---Karlanyone seen the plot
