Auto Box Problem
  • Auto Box Problem
    I've got a wee issue with my auto box. It doesn't change up when I'm accelarating, even very gently. It does change up if I come off the gas a bit.
    It does feel as if it tries to change, but it doesn't seem to do it properly and the revs don't drop.
    The ECT Power button is not pressed, I've tried it with the button out in case it's faulty, the fluid is the correct level, doesn't look or smell burnt and is still red (not a deep red, a kind of washed out red, but red none the less)
    I've checked the fault codes and have 11 & 12, neither are gearbox faults.
    Anyone got any ideas?
    Shameless bump...
      Could be the kick-down cable needs adjusting.
        Kick down cable was OK.
        Next on the list is to check the electrics, then have the oil and filter changed.
        Any other ideas as to what I can try?
