Have a diff oil leak in the rear brake drum, it's definately diff oil and not brake fluid. I can see the oil leaking very slowly from the outer half shaft seal.
Been doing a bit of reading on other threads in the forum, it seems that most people replace the entire bearing to solve the problem, but does anyone have experience in just renewing the 2 oil seals only (without doing the bearing)?
There is nothing to suggest that my bearing is gone. There is no noise or movement in the wheel.
I'd rather renew just the seals than mess around trying to bang out the old bearing. I dont have a press.
Is it easy to renew the outer half shaft seal? Is it even possible without removing the bearing?
The rear inner axle seal looks like it will be relatively easy to do.
BTW, I checked the diff breather and it's not blocked. I took it off and could blow through it.
Any advice would be appreciated.
P
P
