Hi all been running on 50% veg oil mix for 2 weeks now done about 200 miles all seems ok but engine struggles when cold especially these last few weeks when its been frosty. The glow plugs seem to be working ok and i wait for the bong to turn it over engine starts but is lumpy for about 10 mins would a fuel heater cure this i have looked at a few types and found this one http://www.vow2.co.uk/Vow2E.htm Has any one got this type or any tried and tested suggestions?
fuel heaters for running on veg
Several of us have got thisOriginally posted by marcj View PostHi all been running on 50% veg oil mix for 2 weeks now done about 200 miles all seems ok but engine struggles when cold especially these last few weeks when its been frosty. The glow plugs seem to be working ok and i wait for the bong to turn it over engine starts but is lumpy for about 10 mins would a fuel heater cure this i have looked at a few types and found this one http://www.vow2.co.uk/Vow2E.htm Has any one got this type or any tried and tested suggestions?
If you decide to get it a couple of tips
It may pay to get 2, 1 for each side of the fuel filter (at present I have mine BEFORE the filter).
Make sure you insist on 10mm pipe, it comes as standard with 6mm.
TrevLook out Eastbourne, the Pandas are coming !
Hippo is still lumpy when cold, but she can handle the higher %s, well she hasn't complained so farOriginally posted by martyrsvr View Postlol
love the english translation , im also running 50/50 in my truck ,
so does this just aid the lumpy ness or does it mean i can run a higher % of veg oil???
In fairness I am considering adding another heater AFTER the filter to see if the lumpiness problem improves.Look out Eastbourne, the Pandas are coming !
