Fitting LC Springs
  • Fitting LC Springs
    Is it possible to take the top control arm off allowing the axel to drop enough to fit LC springs without compressors. Once in place put wheels on and drop the truck using its weight to allow the control arm bolt to be replaced.
    I've sent Vince a pm but hes not on anyone else done it this way?
    Brian
    id tell u but seem to think im thick.............so i wont
      just take the bottom bolt from the Shock and then take ythe wheel off and have someone stand on the hub once jacked up so you should be able to fit the springs easier
        another classic answer
        ps dont think I've ever given personal abuse to you or anyone else
        Rich thanks would taking the top control arm off allow it to drop more/easier?
        Brian
          u have a very short memory span
            If you have nothing useful to say I would appreciate you not highjacking this thread
            Brian
              Yes in short mate. Im not sure how much of a pig it would be to undo it.
              I'd try Stormforces way an if that fails then check out removing the control arm.
                no worries,u stop with the smart cracks and i will
                  Thanks Rod will try that first. Looking forward to your pics mate, hurry up and get them on!!!
                  Brian
                    I don't think i have heard of anyone taking the control arm off to do the springs
                      It wont work if u have a standard rear brakeline. Disconnect the brakeline and clamp it, then do wot Rich said.
                        1.disconnect both rear shocks from the bottom
                        2.disconnect both sides of thr rear antiroll bar
                        3.disconnect panhard rod
                        4.disconnect brake hose.
                        get someone to step on the rear axle as you insert springs.then re fit everything.bleed brakes job done.
                        www.overfab.uk
                          Perfect cheers
                          Brian
                            I did. The amount you can push down on the axle on the drivers side is limited 'cos the top control arm touches the tank.
                            Removing the shocks is a given as they'll be replaced with longer ones anyway.
                            Just make sure the rigid brake line is uncliped from the axle first.
                              I just did that mate, took arm off cos i needed to relocate the tops, works a treat, the very end of the spring top has to be overlapping the rubber seat, then the rest of the spring sits in its cup, leaving it straight and not touching the shock anymore.
                              Without Surf And Unhappy
