1992 SSR-X 2.4 td
I fitted a new front shocker with suspension set at normal, and wanted to know if the new shocker was set to normal before fitting to ensure that all are the same.
Would it be obvious if they were set differently?
Toyota dealer could not provide further info.
There is also oil seepage at joints in air intake pipes before turbo, engine suffering from back pressure. I have read about head problems on this site and am wondering if it could be valve guide seals rather than worn rings. Has anyone recond an engine and have an approximate cost of required materials.
Any info appreciated thanks Paddy.
