Hi mate, on the phone i mentioned it was a good idea to do 1 turn equally on both sides, then drive it to settle them, then do another single turn on each side, Gradualism is alot safer. Doing one side all in a oner is going to cause problems. Little by little mate, if you do one turn on the RHS also do one turn on the LHS. I had no problems doing it this way and found it no problem without a jack, but use one just incase, just takes a while thats all.
I suggest now that you wind it back down and count the threads to make sure its level again, and start side by side.
ok thanks will do
..........does need to go up again though as is slightly lower at front.
