all the relays i find say what they are on them except the add relay anyone no which one it is ??
add relay
Originally posted by MattF View Postbarwellbomberz
Originally posted by mik View Posti cant get 4wd tested power to 4wd switch ,there is power but when you opperate switch both sides go dead thought it might be relay
Originally posted by MattF View PostIt's just a grounding switch. That's working as it should. Most likely cause of the problem is due to vacuum pipe(s) either being loose or connected incorrectly.barwellbomberz
